4 members (rick46ia, Hotrod Lincoln, Otto Skorzeny, 2-Ton), 101 guests, and 2 robots.
Topics128,034
Posts1,055,547
Members48,425
#3522 01/02/2004 7:37 PM
Can anyone post a picture of a correct muffler mount for a 49 1/2 ton? I've got three pieces but am not sure how they mount to the muffler and to the frame. Thanks
#3523 01/02/2004 10:26 PM
rwise,
Do you know how the muffler itselfs is strapped to the curved muffler bracket under the bed? Here's a couple shots. First was taken when I was replacing the front bed rail. Your muffler strap should be a long piece of strap material and a eye bolt connected to one end with bolt and washer. It's hard to explain how the strap is routed and I can always scan a picture for you if necessary.
Oh yes, I assume a '49 and '50 truck were configured the same in this area.
http://community.webshots.com/photo/97772002/108444467DIfyec
Craig
#3524 01/03/2004 12:10 AM
cmayna, I think the 49 and 50 must be somewhat different. I have the similar bracket that you show but a large ubolt that I assume goes around the muffler and into another bracket on the under side of the muffler
#3525 01/03/2004 2:39 AM
No, the 49 is the same as the 50. A strap as Craig described. One of the vendors sell said strap and eye bolt. Although it is not an actual "eye" bolt, but I do not know what to call it. Sounds like someone has been tinkering with your muffler mount.
#3526 01/03/2004 4:56 AM
Boy,
What it takes to satisfy you guys.....
Please note that the tail end of the strap is pinched between the muffler and the strap itself....
http://community.webshots.com/photo/97772002/108519420dZotIS
Regards
Craig
#3527 01/03/2004 4:08 PM
Thanks Craig, I guess mine was "re-engineered" over the years. I've got Mothertrucker trying to get me a bracket to get mine back to original. Thanks for the photos and diagram. Robin
