3 members (Hotrod Lincoln, 2-Ton, 1 invisible),
63
Mod | | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Can anyone post a picture of a correct muffler mount for a 49 1/2 ton? I've got three pieces but am not sure how they mount to the muffler and to the frame. Thanks | | |
#3523 01/02/2004 10:26 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | rwise, Do you know how the muffler itselfs is strapped to the curved muffler bracket under the bed? Here's a couple shots. First was taken when I was replacing the front bed rail. Your muffler strap should be a long piece of strap material and a eye bolt connected to one end with bolt and washer. It's hard to explain how the strap is routed and I can always scan a picture for you if necessary. Oh yes, I assume a '49 and '50 truck were configured the same in this area. http://community.webshots.com/photo/97772002/108444467DIfyec
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#3524 01/03/2004 12:10 AM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | cmayna, I think the 49 and 50 must be somewhat different. I have the similar bracket that you show but a large ubolt that I assume goes around the muffler and into another bracket on the under side of the muffler | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | No, the 49 is the same as the 50. A strap as Craig described. One of the vendors sell said strap and eye bolt. Although it is not an actual "eye" bolt, but I do not know what to call it. Sounds like someone has been tinkering with your muffler mount. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Boy, What it takes to satisfy you guys..... Please note that the tail end of the strap is pinched between the muffler and the strap itself.... http://community.webshots.com/photo/97772002/108519420dZotIS Regards
| | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Thanks Craig, I guess mine was "re-engineered" over the years. I've got Mothertrucker trying to get me a bracket to get mine back to original. Thanks for the photos and diagram. Robin | | |
