4 members (Hotrod Lincoln, Ranger, Peggy M, carbking), 44 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#35217 12/04/2003 10:49 PM
Ok guys. What rear end gears do I most likely have in my 64? 6cyl/3 on the tree, C10 shortbed. All original drivetrain. Or where are the codes I can look for?
Thanks,Bill
#35218 12/04/2003 11:21 PM
3.90:1 was stock and 3.38:1 the option.
#35219 12/05/2003 1:43 AM
One way to find out: Jack up one rear wheel. turn it one revolution and count how many times the drive shaft rotates. Divide by 2.
