1 members (Steelonsteel),
44
Mod | | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35199 05/11/2004 1:09 AM | Joined: May 2004 Posts: 4 Junior Member | | Junior Member Joined: May 2004 Posts: 4 | I am currently in posession of a 1953 gmc 292 turbo 350 transmission new monojet carberator new distributor no detectable vaccum leaks at stop light in drive it lopes I can not discern the offending componet which originates the aforementioned plight any help would be appreciated
Chuck
#35201 05/11/2004 8:07 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Along with what Fred T. posted, I will add "Check your choke adjustment on your carb"
