6 members (1955 1 Series, Stovebolt48, Otto Skorzeny, Uncles51, 55shaker, Cosmo), 172 guests, and 3 robots.
Topics128,021
Posts1,055,351
Members48,420
#35181 01/07/2005 3:07 PM
what are the tooth cout on a 12v and 6v flywheel.
thanks. jr
1950 3100
1980 "Vette"
2005 Mustang GT
http://community.webshots.com/user/jlr1516
#35182 01/08/2005 2:37 PM
6V is 139 teeth and 12 volt is 168 teeth. If you are coverting to 12 volts you can use your 6 volt starter, or you can convert your six volt to 12 volts, any electrical shop can do it.
Or you can take your flywheel to a machine shop and they can swap out the ring gears. I had my flywheel ground and ring gear changed for 70.00 dollars.
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
