2 members (baldeagle, TPR57C), 60 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#35163 05/25/2005 2:41 AM
My 350 in my 66 C-10 was fired up today. I just rebuilt it. Fired right up, broke in the cam & set the timing but it seems to surge up & down in RPM's. Not really like a misfire but a slower surge, like a vacuum leak or something. I checked all the vacuume lines, manifold, & carb base but I cant really find anything. It really rev's up great out of idle. If I cup my hand over the carb it idles up I smooths out....I'm just sure its in the carb. Any suggestions??
#35164 05/25/2005 11:33 PM
Riding in the Passing Lane
Your idle jets may be too lean or the float level too low. Back the idle jets out about 1 turn. Than slowly turn 1 in till the engine slows down. Back it out about 1/2 turn to where it idles faster. Repeat with other screw. If that doesn,t do it pull the top off the carb & check the float level & blow out the idle are passages.
1972 Chevy c10 Cheyenne Super
