0 members (),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | I don't know if this is a dumb question but here goes: I have a '66 with original 283 SBC. When I rebuilt the motor, I changed the oil pump. Back in the day I remember oil pressures being in the range of 15 or 20 pounds. After I finished the rebuild and put it on my neihgbor's dyno, the pressure in now like 45. Will this ruin or max out my stock gauge? I have the small copper line running from the back of the engine to the dash gauge. Just wondering befor I start it. Thanks to those who know the answer. sovagary
GS
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Gary,
I might be missing the point on this, but any gauge can safely handle pressure up to max value of that gauge. I thought a pretty standard dash gauge would be 0-60 lbs, so this typical gauge would be fine up to sixty pounds of pressure.
Stuart | | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Thanks for that. I'll find out when I get her running.
GS
