| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35147 10/13/2002 3:54 AM | Joined: Oct 2002 Posts: 7 Member | | Member Joined: Oct 2002 Posts: 7 | I recently purchased a 49 1 ton - my first old Chevy. It has a 53 235 engine in it. I don't seem to be able to find an oil filter on it. Did these engines not have oil filters? Thanks!
49 Chev 1 ton 55 **** 800 tractor
growing old is mandatory, growing up is optional
#35148 10/13/2002 4:38 AM | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | They are an add on unit bolted to the intake manifold.Most vendors cary them.Or try the swapmeet.In my webshots album you will see one on my 42.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | |
#35149 10/13/2002 8:10 AM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | the filter was probably removed for who knows why. You can run it with out a filter as long as all the filter lines are plugged, and if you change the oil often. I'd install a by-pass filter myself. Even if it wasn't the original equipment type. Mike | | |
#35150 10/13/2002 8:17 PM | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | For sale on ebay all the time--get the oil lines from the parts house.
Buzz'n Half Dozen
#35151 10/13/2002 11:22 PM | Joined: Oct 2002 Posts: 43 Junior Member | | Junior Member Joined: Oct 2002 Posts: 43 | I added a braket that bolted on to unused stock holes on my 1962 235 so that i could use a spin on type oil filter. The filters are cheaper and easier to replace that the cartrige ones. It works great!  unless you going for the original look. Let me know if ya want the part# for the braket. it's an after market part. | | |
#35152 10/14/2002 2:26 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | PLEASE post part #'s. Thats exactly what i've wanted to do!!! | | |
#35153 10/14/2002 4:18 PM | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Take a look at the main oil gallery and see if you have a fitting and an oil line running around and up to the cylinder head. If you do, let me know and I'll fill you in on what I found with my 235. | | |
#35154 10/16/2002 6:28 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Do the lines to the oil filter cannister need to be flexible or can they be solid? The cannister is bolted to the intake manifold and the manifold is bolted to the block. The lines from the cannister go to the block. So is it logical to think the lines could be solid? Just a question.
Dennis -there is nothing stronger than the heart of a volunteer-
