0 members (), 170 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#35147 10/13/2002 3:54 AM
1 Offline
I recently purchased a 49 1 ton - my first old Chevy. It has a 53 235 engine in it. I don't seem to be able to find an oil filter on it. Did these engines not have oil filters? Thanks!
49 Chev 1 ton
55 **** 800 tractor
growing old is mandatory, growing up is optional
#35148 10/13/2002 4:38 AM
They are an add on unit bolted to the intake manifold.Most vendors cary them.Or try the swapmeet.In my webshots album you will see one on my 42.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#35149 10/13/2002 8:10 AM
the filter was probably removed for who knows why. You can run it with out a filter as long as all the filter lines are plugged, and if you change the oil often. I'd install a by-pass filter myself. Even if it wasn't the original equipment type. Mike
#35150 10/13/2002 8:17 PM
For sale on ebay all the time--get the oil lines from the parts house. wink
Buzz'n Half Dozen
#35151 10/13/2002 11:22 PM
Junior Member
Junior Member
I added a braket that bolted on to unused stock holes on my 1962 235 so that i could use a spin on type oil filter. The filters are cheaper and easier to replace that the cartrige ones. It works great! smile unless you going for the original look. Let me know if ya want the part# for the braket. it's an after market part.
*under construction* 1962 Chev truck: Bagged & bodydropped, shaved, custom made clear tailights & roll pan, custom made aluminum parts.
http://www.geocities.com/philswebsite2003/
#35152 10/14/2002 2:26 PM
PLEASE post part #'s. Thats exactly what i've wanted to do!!!
#35153 10/14/2002 4:18 PM
Take a look at the main oil gallery and see if you have a fitting and an oil line running around and up to the cylinder head. If you do, let me know and I'll fill you in on what I found with my 235.
#35154 10/16/2002 6:28 PM
Do the lines to the oil filter cannister need to be flexible or can they be solid? The cannister is bolted to the intake manifold and the manifold is bolted to the block. The lines from the cannister go to the block. So is it logical to think the lines could be solid? Just a question.
Dennis
