6 members (JW51, Jon G, MRMEROTH11, Peggy M, Southerntruck, 1 invisible), 113 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
#350898 12/21/2007 12:51 AM
Installed cd player in my 59 fleetside and all was well. Now some three months later each time I accelerate it cuts out . I can hear the voltage regulator clicking on and off when this happens. I can also see a visible increase in the brightness of my LED display right before it cuts out. If I just let the truck idle it doesn't happen. Whats up with this.
Ce messam do menmain?
might need to check the gen/reg for problems, it's likely the regulator chattering is more important than the player behavior - I'd think the player cuts out to protect itself from high/erratic supply voltage
deepweasel,
Great handle..... smile
Bill has the right idea, too much voltage! Your charging system needs to be checked.
Stuart
Thanks I will check first thing in the morning
Finally fixed my electrical problems. Seem the contacts in my regulator had somehow welded themselves together. New regulator and once again we have no problem, not to mention sound from the speakers. Thanks guys.
deepweasel,
It's great when you take the time to check back in with the results of a fix...everyone appreciates it, thanks!
Stuart
