7 members (Shaffer's1950, Donf, JoeDude, 48jim1ton, gswbbc, frogfarmer, Gdads51),
120
Mod | | | Forums66 Topics128,032 Posts1,055,516 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 9 New Guy | | New Guy Joined: Jul 2007 Posts: 9 | Installed cd player in my 59 fleetside and all was well. Now some three months later each time I accelerate it cuts out . I can hear the voltage regulator clicking on and off when this happens. I can also see a visible increase in the brightness of my LED display right before it cuts out. If I just let the truck idle it doesn't happen. Whats up with this.
Ce messam do menmain?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might need to check the gen/reg for problems, it's likely the regulator chattering is more important than the player behavior - I'd think the player cuts out to protect itself from high/erratic supply voltage
Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | deepweasel, Great handle.....  Bill has the right idea, too much voltage! Your charging system needs to be checked. Stuart | | | | | Joined: Jul 2007 Posts: 9 New Guy | | New Guy Joined: Jul 2007 Posts: 9 | Thanks I will check first thing in the morning
| | | | | Joined: Jul 2007 Posts: 9 New Guy | | New Guy Joined: Jul 2007 Posts: 9 | Finally fixed my electrical problems. Seem the contacts in my regulator had somehow welded themselves together. New regulator and once again we have no problem, not to mention sound from the speakers. Thanks guys.
It's great when you take the time to check back in with the results of a fix...everyone appreciates it, thanks!
Stuart | | |
