| | | Forums66 Topics128,047 Posts1,055,622 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I am, as usual, confused! I will be dropping the cab on the frame in a few weeks so I began to look around for cab mounts. I don't seem to be able to find what I need for the rear of the cab. All the vendors I have visited show a simple set of bolts like my from cab mounts. I don't see my rear mounts. see picture http://good-times.webshots.com/photo/2292589300099708909JNfYubIs that because only 3600s (3/4 tons) use these and like many other parts for the 3600 and up they don't carry because of little demand? OR, does someone know where I can order these mounts?
~Jim
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | It looks like a rear 1/2 ton mount. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | American Classic lists rear cab mount shackles complete or rubber bushings only. Cleon | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I was just planning on replacing the rubber inserts and cleaning and painting the rest since they show no damage of any kind. Is this the same approach others have used or am I missing something? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | American Classic does list rear shackles but does not give a picture of it. I am a little gunshy here and afraid to order if I don't see the product. Anyone else know where I can order this that posts the pics.?
~Jim
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Your mounts look fine and should only need rubber bushings. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks Ghostrider, that's what I've been looking for.
~Jim
| | | | | Joined: Mar 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 37 | yeah, On my 1949 3600 the Whole shackles are rusted. Does anyone know where to buy those? thanks alot,mike | | |
