| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bill,
I haven't used that product. My only question would be if this were intended for outside exposure to the elements...primarily the sun and its UV rays.
There are probably architectural or marine products that would block the UV rays that you could apply over the dye/stain...or, maybe you park your rig inside.
What does the manufacturer say about using this product outside and the effects of sunlight on it.
Stuart | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Stuart,
I'll have to check on the exposure effects. The product you use to seal the wood after applying the dye is probably more important. But I will check.
Thanks, | | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | I've used aniline dye for part of the running boards on my '46 Panel but I used alcohol based dye not water. It was not this product. Like it has been said you have to use the right top coat to protect it. I used Gold Star Marine urethane. I like the alcohol based dyes, I tested both for my need, they seem to penatrate better and have a deeper color.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I built a sleigh a few years ago and had the same problem, how to get a red stain. I went to Sherwin-Williams and had them mix a red and green stain for me. It was the same type of stains that they use to get walnut, cherry, oak etc. They just mixed in lots of red tint to a mixture of clear stain. It turned out great, used Helmans Spar Urethane to top coat, just as red and green today as it was 10 years ago. It sits outside every Christmas for a month or so every year. Hope that helps. | | |
