1 members (baldeagle), 91 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#349739 12/17/2007 2:54 PM
I've been looking on old postings about engine ID but have not found what engine I have. The # stamped on plate by distributor are 0258603F54XA and the (03) are stamped deeper than the rest. Would really appreciate any feedback
Squeegebob
squeegebob #349838 12/17/2007 7:34 PM
Ex Hall Monitor
Ex Hall Monitor
Take the "Tech Tips" link at the top of the page. Under "Indentify your truck" click the VIN buster. Put in your info & bingo.
Tiny #349841 12/17/2007 7:50 PM
The F54 shows it's a 1954 (full pressure) engine made in Flint, MI. The XA I believe shows it to be a truck engine but maybe someone else will come along with more info.
waldo53 #349908 12/17/2007 11:52 PM
XA is for a 3600.
Bill Burmeister
waldo53 #349913 12/18/2007 12:02 AM
Welcome to the Bolt Squeegebob.
Here is the "overexplanation" of what everyone else said if you wonder where you could find the info yourself.
These two sites should tell you what you need to know. Look under 1954 - 1957 Engines on the first page and you will see an example and explanation of how your engine number is laid out. You won't find the "XA" explained on this page.
http://chevy.tocmp.com/models/engine.htm#54eng
This second site provided by one of our site sponsors gives the XA definition. Put "1954" in the Engine Code menu.
http://www.americanclassic.com/paint.htm?p1=engines
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
randyl #349954 12/18/2007 1:44 AM
Thanks guys,
It sure helps to have all these experts at your fingertips. I will probably be asking alot of question this is my 1st restoration . Your answers are all correct, the truck I'm restoring is a 1954 5window 3600 1st series.
Thanks again,
Squeegebob
squeegebob #350012 12/18/2007 3:56 AM
Squeegebob,
There is no need to say "1st series" for a 1954 truck - there was only one series in 1954. In 1955, there was a 1st series (that looked a lot like the 1954 truck) and a completely new design 1955 2nd series.
Tim
