| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 18 New Guy | | New Guy Joined: Nov 2007 Posts: 18 | I've been looking on old postings about engine ID but have not found what engine I have. The # stamped on plate by distributor are 0258603F54XA and the (03) are stamped deeper than the rest. Would really appreciate any feedback
Thanks, Squeegebob
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Take the "Tech Tips" link at the top of the page. Under "Indentify your truck" click the VIN buster. Put in your info & bingo.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The F54 shows it's a 1954 (full pressure) engine made in Flint, MI. The XA I believe shows it to be a truck engine but maybe someone else will come along with more info. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Welcome to the Bolt Squeegebob. Here is the "overexplanation" of what everyone else said if you wonder where you could find the info yourself. These two sites should tell you what you need to know. Look under 1954 - 1957 Engines on the first page and you will see an example and explanation of how your engine number is laid out. You won't find the "XA" explained on this page. http://chevy.tocmp.com/models/engine.htm#54engThis second site provided by one of our site sponsors gives the XA definition. Put "1954" in the Engine Code menu. http://www.americanclassic.com/paint.htm?p1=engines
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Nov 2007 Posts: 18 New Guy | | New Guy Joined: Nov 2007 Posts: 18 | Thanks guys,
It sure helps to have all these experts at your fingertips. I will probably be asking alot of question this is my 1st restoration . Your answers are all correct, the truck I'm restoring is a 1954 5window 3600 1st series.
Thanks again, Squeegebob
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Squeegebob,
There is no need to say "1st series" for a 1954 truck - there was only one series in 1954. In 1955, there was a 1st series (that looked a lot like the 1954 truck) and a completely new design 1955 2nd series.
Tim | | |
