0 members (),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34968 02/29/2004 4:26 AM | Joined: Feb 2004 Posts: 6 Member | | Member Joined: Feb 2004 Posts: 6 | The truck I just bought" 41 half ton" has a carter yf carb currently on it, and I also have a carter w-1 that is in a box of parts that came with the truck, I know nothing about these things and was wondering what was the difference between them thanks | | |
#34969 02/29/2004 4:41 AM | Joined: Nov 2002 Posts: 2,764 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,764 | A Carter W-1 (Carter made 128 different W-1 carbs) was original equipment in 1941 on Chevrolet, both passenger and truck. The W-1 was Carter's standard 1-barrel during this time, and is an excellent carburetor.
Carter released the YF in 1950. This carb was one of the finest (possibly the finest) 1 barrel carbs ever made. Again, Carter made hundreds of different ones, for many different size engines. YF carbs were very advanced, and continued to be used up through the mid-1980's on other brands.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#34970 03/02/2004 7:42 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Carbking, I have a Carter YF sitting around and it looks pretty good. My 55.1 has a rochester in it.
1. Is that a good exchange?/ will it fit?
2. What is a good rebuild kit brand?/ where can I get them?
55 1st Chev.
#34971 03/02/2004 11:56 PM | Joined: Nov 2002 Posts: 2,764 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,764 | It depends on what YF you have. These were used on engines from 134 to 300 cubic inches; and thus all YF's are not the same size. If the one you has is one designed for your engine (or a very similiar unit), should work well for you.
I believe board ethics prevent me from answering your second question.
