2 members (J Lucas, lumbersawyer), 129 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#349516 12/16/2007 8:57 PM
Will 2002 Chev wheels fit my 54 3800??
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Stick #349530 12/16/2007 9:52 PM
You've probably got 18" tube-type tires on it now, right? Even if the 8-lug bolt pattern matches up, it takes a tubeless tire wheel of 19.5" or bigger to clear the rear brake drums. My 59 model 3800 would accept 16" drop-center (tubeless) wheels on the front hubs because it had a spacer built in for the correct track width, but the inner wheel wouldn't go over the rear brake drum.
Nope, got crappy spoked 16.5s, what was on it when I got it...
I've rounded up 4 16's for the rear and found the 2002 16's, hoping
for the front...
Geoff
68 GMC 3800
Stick #349653 12/17/2007 3:39 AM
You can learn more about the 2002 wheels at www.accuride.com.
Their catalogs give some good information including the specs of later wheels. I learned about that site from others here, so if it helps the thanks goes to the community, not me.
Correction: www.accuridewheels.com
OldSub #349727 12/17/2007 1:24 PM
Steve - I seem to be getting a site way different than wheel spcs when I click on your link. Am I missing something here?
Doug
OK, try this one http://www.accuridewheels.com/car_lt_truck.asp
Doug
desertdog #349752 12/17/2007 3:42 PM
I've got old 8R19.5's on mine. Check this site out if you want to get the nice (but expensive) 19.5 tires and rims. http://www.ricksontruck.com/wheels_gm_drw.html
There are other places that can sell you steel rims cheaper. I'd love to have those 285 /70R/19.5 tires and rims. Those extra inches in diamter will help your speed out as well.
Are your current wheels hub or lug centered? What is the center hole diameter? What is the wheel offset? Do you have 1/2" or 9/16" lugs? You'll need to know this kind of stuff to get new rims.
