8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84040 10/10/2007 8:42 PM | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | Hi Guys, I've just bought an 83 S10longbox with a very tired 2.8 auto trans combination. I'm looking to eventialy do the AD engineering swap on this frame as it is very solid. I'm shooting for fuel economy on this next ride. So my question to those that are in the know is what sort of engine is the 2.2 litre iron duke or should I look at the 2.5 litre instead ? Any words of wisdom from those that are in the know would be appreciated. Thanks  Don | | |
#84041 10/10/2007 9:19 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Both those would not have enough power to make a good swap. You could rebuild or get another 2.8. They are not overly powered but run pretty good. Some say they don,t stand up to good but i,ve seen them run a long time. I put a small block v-8 in an S-10 one time & it shure worked slick. It was a lot of work & expense though. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#84042 10/10/2007 9:26 PM | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | Well, I've already got a truck with a 350 in it, but this time I'm aiming for fuel economy. This truck will be used around town and not on the highway so I'm not looking for a power house. | | |
#84043 10/10/2007 10:22 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Don't accept that an Iron Duke or the other one for that matter wouldn't have enough power. The Poncho was used very satisfactorly in a mid-size car for several years and they ran just fine. It ought to be a good choice for what your after. | | |
#84044 10/11/2007 2:45 AM | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | Oldkoot, should work. Iron duke from what I read run 84 horsepower for carb models, 92 horsepower and up for fuel injected. Depends on what year iron duke you get. fuel wise I would say it was a power to weight thing. Consider the truck you buy to set on the s 10 chasis. Most s 10 frame swaps I see are later 40's to early 50's chevy advanced design. The frame engine, trans and front and rear axles with springs,wheels and tires on these trucks compared to s10 running chassis. The s10 I should think is 600 to 800 pounds lighter. I think what you'll have is an old looking truck that runs and drives like an s10 with a iron duke in it. I would get the fuel injected model more power and better fuel economy.
jbennett 40 burb | | | | | Joined: Dec 2007 Posts: 30 Apprentice | | Apprentice Joined: Dec 2007 Posts: 30 | I recall.....When the Chevy 2 came out in 1962, the standard engine was a 4 cyl. that was the new 194 cu. 6 shortened to 4 cyl. That base engine was offered for years but did not sell well so they sold it to Evinrude/Johnson. They used it for many years. The hot set up in those days was to find a head from a boat motor (crossflow -more H.P.)When Chevy realized that the Vega had failed, and they had no 4 banger for the wave of small cars coming out, they bought it back and reintroduced it as the "Iron Duke". I think it was bored slightly so they could use pistons off the pontiac V-8 . Then with the development of the "new chevy of the 80's" - the Citation, it was reintroduced with a crossflow head for sideways mounting of the engine in that front wheel drive platform. Those heads do not interchange on earlier blocks since they also changed the head bolt pattern. The motor is a very tough design(chevy -6 basically). TerryJ | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Just to add a little info, those original old Iron Duke 4-cylinder engines were 153 Cubic Inches.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Dec 2007 Posts: 30 Apprentice | | Apprentice Joined: Dec 2007 Posts: 30 | Hi C-10 C-90 Bill, Yup, I can never keep them straight. If the iron Duke was 153c.i. then the Chevy 2 motor was 151, or was it the other way around? The difference was the Pontiac pistons they borrowed. TerryJ | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Why can't you use a turbocharged 4 cylinder? GM makes them, and they were quite strong. There's a turbo 2.2 good for 260 hp in the new Pontiac Solstice, and the Olds Quad 4 engine was a turbo motor that made quite a bit of power too.
Thing about a turbo motor is, keep out of the throttle, and it's just a regular 4 cylinder motor. But you know, if you under-power a heavy vehicle, not only will you have the aggravation of being so underpowered, but also, your gas mileage will suffer because of how hard the motor needs to work.
Just a suggestion. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A suggestion to make thing easy, GM has a EPA approved upgrade engine for S10s that originally had the 2.8. It's a 3.4 liter (207 cid) engine, same bore and stroke as the 4 cam engine, but uses the std heads and block. It's a bolt in engine, no cutting, odd mounts, and will bolt up with the existing trans. It should have plenty of power and decent economy, too. It's GM part # 12363230. Rated at 160 hp and 194 ft/lbs. It only needs the intake, ignition, exhaust, water pump (and belt drive) and an electric feul pump to install. BTW, I've never seen a turbo Quad 4, and from my own experience, they are a very doggy engine, even in a light weight front driver.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | My opinions as follows - Either pick up the 3.4 like Bill says. Or get a 3.4 from a 94 and newer camaro and take the whole fuel injection setup, etc. for 170Hp. I went with a camaro 3.4 / 5-speed for an RX7 conversion that I did. Drove it for over 100000 miles in 5 years getting 28MPG with the 4:10 gears in the RX7 prior to selling it. The Quad 4 2.3 liter is a much better engine than the old 2.0 or 2.2 isuzu or even the 2.5 pontiac (Tech 4). I had a Tech 4 in my '85 S-10. Fuel economy is as bad with the 2.5 as it is with the 2.8 that you had, however less power. Put a hot cam, and ditched the fuel injection for a Holley 350 CFM carb and distributor from a 1980 Pontiac Sunbird. It woke the 2.5 up, however I did end up putting in a Buick 3.8 that I had from another project. The new Ecotech engine (Found in Solstice, Cobalt, Opel Speedster, Saturn Sky, etc.) is actually GM's world engine designed and manufactured by their Opel Plant in Germany. Nice engine that you can get up to 1000hp out of if you need - just not for street at those levels. For the street, get the GM performance Supercharger for it. You can pull any fuel injected GM V8, overdrive trans and EFI from the Mid 80's or newer and get more power and fuel economy than the 2.8 had. Visit here for more information. Another choice is the 4.3 liter that you will find in many S-10's Scott
