| | | Forums66 Topics128,091 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34902 12/06/2004 12:03 AM | Joined: Oct 2004 Posts: 11 Junior Member | | Junior Member Joined: Oct 2004 Posts: 11 | My recently acquired 1952 2-ton utility dump truck was purchased with no info other than it's been sitting for 10 years. Before that everyone agrees it was a great truck. Now that I have the engine running with minimal effort, I'm finding no brakes and no apparent clutch. The fact that the cover was off the clutch (sitting in the front seat), should have warned me. Suggestions? Is it safe to put it in gear and push or drag the truck to "break things loose"? Or is the better part of valor to drop the tranny and better know what I'm dealing with first?? What tranny is likely on this truck? Anyone know what a clutch kit is likely to run if we do the work? Thanks for any insight Mark | | |
#34903 12/06/2004 12:19 AM | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | I'm assuming that the clutch isn't disengaging when you're pushing the pedal. First make sure that all the linkage is operating properly. You should be able to see the throwout bearing move on the tranny input shaft when you press the pedal. It could be way out of adjustment and isn't moving far enough. If this isn't the case, it is possible that the clutch disc is stuck to the flywheel. I had this happen to me on an old tractor. The easiest way to break it loose: Put the tranny in high gear. Set the parking brake as tight as you can get it. Push the clutch pedal. Hit the starter. It should break it loose. If a few attempts won't do it, it's probably time to drop the tranny and take the clutch apart. Good luck
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | |
