4 members (Hotrod Lincoln, BC59, 2 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34810 09/09/2002 12:31 AM | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | F0719HF on the pad next to dist. appears to be a 63 or older as it has a gen rather than alt and the pan isn't a nova. my books don't go back that far.....
i miss obscene phone calls...
#34811 09/09/2002 1:35 AM | | Anonymous Unregistered | | Anonymous Unregistered | Stamped # on the distributor is unreliable. Best # to use is the one cast in the block near the starter [ it will start with CON.......... ]. Post these #'s & letters & we can tell you the month, day, & year the block was cast. | | |
#34812 09/10/2002 1:26 AM | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | i dn' really care about what year, just what tthe cid is. the block ain't here, so the casting numbers arn't readily available. i already know it's not a 292(dammit!)
#34813 09/10/2002 4:19 AM | Joined: Sep 2002 Posts: 21 Junior Member | | Junior Member Joined: Sep 2002 Posts: 21 | Mothertrucker,
How can I decode my #? I found CON1 A223. Based on guess work, I assume the CON1 = 235? And A = January, 22 is the day of the month? And the 3 is for 1953? Is any of this guess work right? Thanks for any help!!
Ohayden -------------------------------- 53 Chevy Coupe (Daily Driver) 67 Chevy Camaro (Toy) 68 Chevy Camaro (Weekend Driver)
