4 members (TexasJim50, baldeagle, Hotrod Lincoln, 1 invisible), 100 guests, and 3 robots.
Topics128,018
Posts1,055,340
Members48,419
#34810 09/09/2002 12:31 AM
F0719HF on the pad next to dist.
appears to be a 63 or older as it has a gen rather than alt and the pan isn't a nova.
my books don't go back that far.....
i miss obscene phone calls...
#34811 09/09/2002 1:35 AM
Anonymous
Unregistered
Anonymous
Unregistered
Stamped # on the distributor is unreliable. Best # to use is the one cast in the block near the starter [ it will start with CON.......... ].
Post these #'s & letters & we can tell you the month, day, & year the block was cast.
#34812 09/10/2002 1:26 AM
i dn' really care about what year, just what tthe cid is.
the block ain't here, so the casting numbers arn't readily available.
i already know it's not a 292(dammit!)
#34813 09/10/2002 4:19 AM
Junior Member
Junior Member
Mothertrucker,
How can I decode my #? I found CON1 A223. Based on guess work, I assume the CON1 = 235? And A = January, 22 is the day of the month? And the 3 is for 1953? Is any of this guess work right? Thanks for any help!!
Ohayden
53 Chevy Coupe (Daily Driver)
67 Chevy Camaro (Toy)
68 Chevy Camaro (Weekend Driver)
#34814 09/10/2002 11:12 AM
Tom, from http://no25.homestead.com/page3.html
I'd say you're dealing with a 62-64 194.
