| | | Forums66 Topics128,163 Posts1,056,921 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34670 07/08/2004 4:27 PM | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | Does anyone know who sells a fan shroud to fit my 1965 C10? I am running a later model (larger diameter) clutch fan with the stock radiator. Thanks, Mike | | |
#34671 07/08/2004 6:14 PM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Straight 6 or V8? LMC Truck sells one for V8 but, it's about $100. Seen 'em on ebay the last couple weeks for cheaper. The search I used when I saw them was "65 chevy truck". Not sure what the difference is between the 6's and 8's as they had the same radiator. I suppose just the position of the fan. I've often wondered if that V8 shroud would fit on my 292, or if I could make it fit. If a stock one would work for you I guess depends how much bigger your fan is from stock one. | | |
#34672 07/08/2004 6:23 PM | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | I have a 350. Guess I should have given that one LITTLE fact. I heard that the '65's didn't come with shrouds. | | |
#34673 07/08/2004 8:33 PM | Joined: Feb 2004 Posts: 29,853 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,853 | The length of the shroud is critical to correct fan performance. The fan blades should fit halfway into the back end of the shroud, so the fan hub is just even with the rear of the shroud. Too far forward or back will result in incorrect air flow through the radiator, and/or oddball noises. Also, any areas around the sides of the radiator should be covered with sheet matal, so all the air passes through the core. That's not usually a problem with a stock radiator, but on a custom job, sometimes it gets forgotten. Jerry
#34674 07/08/2004 11:19 PM | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | HotRod, Thanks for the info. I am up on the physics of shrouds and the like, but I SURE don't want to have to build one. Right now I am in a time crunch, and buying one would be SO much nicer. More as the stomach turns. | | |
