7 members (55shaker, EchoBravoSierra, 46 Texaco, BarryP, Otto Skorzeny, Shade Baby, Phak1), 159 guests, and 1 robot.
Topics128,162
Posts1,056,910
Members48,458
Does anyone know who sells a fan shroud to fit my 1965 C10?
I am running a later model (larger diameter) clutch fan with the stock radiator.
Mike
Straight 6 or V8? LMC Truck sells one for V8 but, it's about $100. Seen 'em on ebay the last couple weeks for cheaper. The search I used when I saw them was "65 chevy truck".
Not sure what the difference is between the 6's and 8's as they had the same radiator. I suppose just the position of the fan. I've often wondered if that V8 shroud would fit on my 292, or if I could make it fit.
If a stock one would work for you I guess depends how much bigger your fan is from stock one.
Tradin' up dimes for nickels...
My \'65 Chevy C-20
I have a 350.
Guess I should have given that one LITTLE fact.
I heard that the '65's didn't come with shrouds.
The length of the shroud is critical to correct fan performance. The fan blades should fit halfway into the back end of the shroud, so the fan hub is just even with the rear of the shroud. Too far forward or back will result in incorrect air flow through the radiator, and/or oddball noises. Also, any areas around the sides of the radiator should be covered with sheet matal, so all the air passes through the core. That's not usually a problem with a stock radiator, but on a custom job, sometimes it gets forgotten.
HotRod,
Thanks for the info.
I am up on the physics of shrouds and the like, but I SURE don't want to have to build one.
Right now I am in a time crunch, and buying one would be SO much nicer.
More as the stomach turns.
