| | | Forums66 Topics128,057 Posts1,055,815 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34654 11/15/2003 12:20 AM | Joined: Nov 2003 Posts: 4 Member | | Member Joined: Nov 2003 Posts: 4 | would a 1959 six bolt wheel pattern rear end be a bolt in for my 1953 3100? | | |
#34655 11/15/2003 12:38 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | More or less, you may just need to move the spring perches.
#34656 11/15/2003 8:43 AM | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | Thats real close to what you have and would open the drive line up if thats what your after. You need to weld the rear end at the right angle. Go to a weld shop,spend 20-30 clams to have it done so its safe. I put a 57 on my 54 and it worked out very well with little rework. All your stuff,brakes will hook right up, no complications. Have you thought about a T5? Check out the tech. here.O | | |
#34657 11/15/2003 11:47 AM | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | I have a '49 axle with a '57 center section. In your case I believe you can do the same, just keep your '53 axle, lose the closed driveshaft and pumpkin, insert the '59 differential, get an open driveshaft transmission and driveshaft to fit. I burned off the '49 pivot and welded on new spring perches at the proper drive angle. Your choice. As was said previously, you don't gain much, I went from a 4.11 to a 3.90 as you would if you did this swap, but it then became open drive. I use a .70 overdrive. Here's the math, .70 X 3.90 = 2.73, final drive ratio. I go 75 mph no problem @ 2100 rpm's with LT 215 85R 16 radials.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
