2 members (Otto Skorzeny, 1 invisible),
107
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 54 | How can you tell what tonnage this truck is?? It has 5 lug nuts. Thanks | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | If it's 5 lug front, & 10 lug rear, it's a 1 1/2, or 2 ton. To differentiate the two, the next question is, do you see a ID (VIN) plate under the passenger side hood, rivited to the outer edge of the cowl. If so get the number from it, & someone here with decifer it for you. Does it have a 2 spd. rear axle. If so, 2 ton. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Did Chevy offer a 2 ton in 46? A friend of mine just bought a 45, and we were lead to believe that Chevy only went up to 1.5 ton in those years. His even has a sort of double frame, and is supposed to be a 1.5 ton.
With 5 lug fronts and 10 rear it's bigger than a 1 ton for sure.
48-53 trucks are more my thing, so I may be wrong on the older ones. Grigg
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | 1946 was indeed the first year for the 2 ton rated Chevrolet trucks. If on the ID (VIN) plate you find the first two letters "OR", "OS", "PJ", or "PK", it's a 1 1/2 ton. If you find "OE", "OF", "PV", or "PW" it's a 2 ton. | | |
