4 members (klhansen, 32Fordpuchoptop, FAST55, walter74), 95 guests, and 2 robots.
Topics128,120
Posts1,056,319
Members48,439
What's the diff in this engine and the conventional passenger vehicle 292 engines?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1842265714
Just from the pics, it looks like the rear fo the block does not have the appropriate size flanges to attach a bell housing to. The cast flanges on my 292 appear to be much larger, allowing the use of different bell housings and transmissions.
Hippieump
3rd Generation 53 5window
The Mercruisers have the same bellhousing mounts as the automotive models - they used a special "mini" housing. Some of the 292s used a hotter cam and 4-barrel carb but I don't think the 225 HP rating is correct, the standard 292 Mercruiser was 175 HP, the performance model was 200 or 205 HP if I recall correctly. Other differences are that the intake and exhaust manifolds are water cooled (expensive) and valve cover and pushrod covers are alloy castings.
I can't tell from the picture, but the Mercruisers sometimes also sported a very nice aluminum valve cover. That one might be painted over - worth a few bucks just for that, very popular add-on. Been looking for one for my 250... smile
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
