| | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | If you use these on the A.D. what do you do about the outside door handles? Also, what about security, are locking mechanism included?
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | | Houston54 Unregistered | | Houston54 Unregistered | I do not think the pull down handles will work with the bear claws but I have never looked at their function to confirm this. If you have the push button handles it will work fine. See my write up I posted previously to your initial thread on this subject.
If you have the pull down handles you may have to analyze how they operate to see if a way to activate the latch can be fabricated. None of these are true plug and play systems. You will have to "make" it work unless you plan to use door poppers.
As for security I am using the push forward feature of the inside door handle to lock my doors. Works just fine. | | | | | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 | Molileortho: I'm putting bear claws in my 52 right now (my 52 has swing down handles from factory)I followed Houston54's write up but I put the pulley at the front of the door just above the top hinge (that's the real hard part) I modified the inside assembly by cutting the end and attaching a spring piece to it because I found the latch to touchy. I drilled a hole about half way down the arm to attach the cable and made an L piece to drop down in front of the inside assembly for power door lock because the bear claw lock wouldn't allow me to lock the door and close it. The outside handle shaft was cut to 1.25" squared and tapped for a 2.5" arm and a spring attached to keep the handle up. Hope this helps. Jeff http://s119.photobucket.com/albums/o142/dapapa_photos/Doors/
New deal for old steel
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Looks good, can't wait to see the finished product!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 | Mobileortho:I just finished a post on the door forum about the bear claws if you want to take a look. Jeff
