| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 31 Apprentice | | Apprentice Joined: Nov 2007 Posts: 31 | i want to put front disc brakes in my 58 apache .is there anything we can use (besides buying kit which is too expensive)from another type that would be compatible? also is there a site that has alot of pictures (for colors) so i can get an idea of what color to paint... thanks doug | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Doug, You can use the complete front brakes (rotors, calipers & hoses)from a 74-77 Malibu. I think that same era camaro may also work. Then buy the bracket kit from one of the aftermarket suppliers. You are not done there however as you will still need a power booster, master cylinder, & proportioning valve (under the floor type). It's probably better to buy the booster assy as a kit. Fred Note: This will give you a 5 x 4 3/4 bolt pattern. The six lug conversions are more complicated.
| | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I did allot of research on this in attempts to avoid buying a 6 lug kit. I don't know exactly what rotors to use, but have some ideas. Hoses, calipers & brackets per above work for 5 or 6 lug. '70-'78 or so Camaro calipers are what's in the kits. In the end, I'll probably buy a kit. Are you are going to go 6 lug or 5?
Ebay is a good place to see trucks of various colors. Other sites that sell trucks too. There is also the Stovebolt Gallery. | | | | | Joined: Nov 2007 Posts: 31 Apprentice | | Apprentice Joined: Nov 2007 Posts: 31 | thanks for the info on the brakes and colors it's gonna save me lots of money doug | | |
