0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 34 | with a 3100 54 1st series that has a splash pan in the front, there doesn't appear to be enough room to insert fog-lights and their stem mounting brackets that affix to the bumper supports. Is this correct and do holes need to be drilled into the splash pan?
cam | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | from the 1954 Accessories installation Manual for 1954 cars n trucksHole location for 3000 series with or without Grill guardLocate two holes in stone garde by measuring from center line of truck 20_1/2 " towards the outer ends of the stone guard and mark stone guard. then at the 20_1/2" marks on stone guard measure from front edge so stone gaurd towards grille 3" and scribe centers and drill two 13/32" holes in stone guard, as shown in fig139 (no pic of fig 139) so no the bumper brkt mounts are not use and they are monted to the front splash apron or "Stone Guard" These books are kinda neat (get you buddy to buy some)  Mike | | | | | Joined: Jul 2007 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 34 | Just what I needed, thanks Mike- cam | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i welded a 1'' sq. box tube along w/ a tab to hold the fog light stem under the apron surface lengthwise. supported at both ends by the apron support arms. the tab is in position for my fog lamps, is just at the edge of the grill so as to not hinder air flow into the grill. this will also help just incase you're little loved one wants to look into the engine comp and help dad.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | The correct fogilghts had a small 90 degree angle base which mounted to the splashpan with a bolt. Just about any foglight could be made to work. | | |
