| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 29 New Guy | | New Guy Joined: May 2006 Posts: 29 | Needing some help, does a 64 c-10 have self adjusters on the rear brakes? I'm in process of restoring a 64 c-10 while attemping to replace the rear brakes I noticed no adjusters, no hole in the drum or backing plate for adjusting, and no mechinism to keep the adjusters from turning. I wondering if the preivous owner removed the self adjusters? | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I have a 64 C10 and did a complete brake job on it, and there were self adjusters on mine. I know they were original, as my truck came from my grandparents, and I'm only the second owner. 64 is the first year that Chevy came out with self adjusting brakes. Good luck. Tramp | | | | | Joined: May 2006 Posts: 29 New Guy | | New Guy Joined: May 2006 Posts: 29 | Thanks Tramp, I purchased a spring kit thought it was wrong looked at others they were the same, it let me to believe I had parts missing from my brakes, your post confirms it. I found self adjusters for a 64 in one of my old truck catalogs, I'll be ordering. I guess at some point in time someone decided they were not needed???? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Those parts are all available from the local parts store. The self adjuster kit comes one for each side. The return & hold down parts come in a kit that does both sides. It,s usually called a Combo-kit but different brands have there own name. The emergency brake parts in side are hard to come by if someone left them out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
