| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34535 04/20/2004 7:20 AM | Joined: Feb 2004 Posts: 60 Member | | Member Joined: Feb 2004 Posts: 60 | Anyone have their flywheel start vibrating at certain rpm's from coming loose? I'm hoping this is where my vibration around 2000rpm's is from. Also if I remove the flywheel cover is there enough room to check/ tighten everything easily?
Thanks for any help, Jason | | |
#34536 04/20/2004 8:25 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Vibration can come from many sources,,, fan, water-pump, alternator/generator, engine timing etc. you will not be able to get to the flywheel bolts through the inspection cover as the clutch is in the way.
