1 members (baldeagle), 53 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
Anyone have their flywheel start vibrating at certain rpm's from coming loose?
I'm hoping this is where my vibration around 2000rpm's is from.
Also if I remove the flywheel cover is there enough room to check/ tighten everything easily?
Thanks for any help,
Jason
Vibration can come from many sources,,, fan, water-pump, alternator/generator, engine timing etc.
you will not be able to get to the flywheel bolts through the inspection cover as the clutch is in the way.
