5 members (ShopRag, kurbside bolter, Ponchogl, cmayna, 1955 1 Series), 107 guests, and 4 robots.
Topics128,268
Posts1,058,375
Members48,485
#345197 12/05/2007 11:28 PM
Apprentice
Apprentice
im looking for ring and pinion set and was just wondering what the stock 47-53 AD trucks back axles are called,are they just chevy 12bolt or something else
What size truck do you have?
I don't know for sure what you call them but they are GM made axles.
Don't plan on finding new gears unless you want the 3.55 gears for a 1/2 ton
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #345283 12/06/2007 2:14 AM
And, do any vendors now have the 3.55 set in stock at this time?
1 Offline
sorry its a 49 3100 a 3.55 was about what i wanted anyways,was going for a 3.42 but close enough,have any of you switched to theses gears and if so what did you buy em for
Sounds like you are under the impression that there are lots of gear choices for these old trucks, and that they are readily available.
You will find this is not true.
You are in luck because you have a 1/2 ton, and the demand is such that aftermarket fast (3.55) gears were made, and may still be.
here is a tech tip on installing them
http://www.stovebolt.com/techtips/rear_end/index.html
And where to get them http://www.patricksantiquecars.com/
Grigg
---All pictures---
Grigg #345487 12/06/2007 3:59 PM
You might want to ask if the 3.55 gears are in stock and indicate that you do not want to be charged until the gears ship to you.
