6 members (klhansen, Peggy M, Maybellene, TexasJim50, Hanks custodian, Woodcmiami), 92 guests, and 2 robots.
Topics128,059
Posts1,055,820
#345119 12/05/2007 8:45 PM
Cam
Offline
with a 3100 54 1st series that has a splash pan in the front, there doesn't appear to be enough room to insert fog-lights and their stem mounting brackets that affix to the bumper supports. Is this correct and do holes need to be drilled into the splash pan?
cam
Cam
An amateur expects things to work, and is surprised when they don't; a professional expects things to not work and is surprised when they do."
1954 Chevy 3100 1st Series in the Gallery
More at my Picasa site
Cam #345125 12/05/2007 9:03 PM
OLTrucks
Unregistered
OLTrucks
Unregistered
from the 1954 Accessories installation Manual for 1954 cars n trucks
Hole location for 3000 series with or without Grill guard
Locate two holes in stone garde by measuring from center line of truck 20_1/2 " towards the outer ends of the stone guard and mark stone guard. then at the 20_1/2" marks on stone guard measure from front edge so stone gaurd towards grille 3" and scribe centers and drill two 13/32" holes in stone guard, as shown in fig139 (no pic of fig 139)
so no the bumper brkt mounts are not use and they are monted to the front splash apron or "Stone Guard"
These books are kinda neat (get you buddy to buy some) grin
Mike
#345126 12/05/2007 9:05 PM
Cam
Offline
Just what I needed, thanks Mike-
cam
Cam
Cam #345411 12/06/2007 7:04 AM
i welded a 1'' sq. box tube along w/ a tab to hold the fog light stem under the apron surface lengthwise. supported at both ends by the apron support arms. the tab is in position for my fog lamps, is just at the edge of the grill so as to not hinder air flow into the grill. this will also help just incase you're little loved one wants to look into the engine comp and help dad.
Jim & Caroline
The correct fogilghts had a small 90 degree angle base which mounted to the splashpan with a bolt. Just about any foglight could be made to work.
My Trucks
Stuff I Collect
