| | | Forums66 Topics128,263 Posts1,058,348 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | I had a question regarding the window crank mechanism on my '66. What is the best way to lube them so they crank easier? I don't think I need to take them apart because they look like in good shape, but crank hard. Can I use WD40? or does that make dirt stick more? How about silicon spray? I have the inside door panels off so can reach in there a little. sovagary
GS
| | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | Grease bout any style you choose but grease it stays where you need it longer. WD40 is ok for quick lubing of rusted items but what you want is something that will still be where you put it (or there abouts)next year. you will want to remove your assembly from the door and lube the teeth and where the arm slides over or contacts any other part of the assembly and make sure you get plenty in the small gear portion too. Now one question I have is dose it seem tight n stiff when its out of the door a lot of the time its misalignment or binding that can cause it to be hard to roll up or down. in that case you will need to check the channel or even you may have a stuck or broken roller. Just a few thoughts Mike
| | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Thanks for the tips. I will adopt this for sure. Gary
GS
| | | | | Joined: Jul 2006 Posts: 40 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 40 | Go to your local parts store and buy a can of spray white grease and spray the gear mechanism and the slides where the rollers go. Sometimes what happens with a lot of use on these regulators is the back of the crank shaft that turns the big gear on the regulator get warbeled out and then the gears slip, or a roller either seizes up or cracks, so while you have your door opened up check this out. | | |
