1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 11 Apprentice | | Apprentice Joined: Sep 2007 Posts: 11 | got my 36 high cab torn down to a bare frame. the frame is severely bent. I'm going to have to remove all the crossmembers and put each of the frame rails in a press to straighten them. I need to know, are the sides of the frame rails supposed to run straight or do they have a curvature to them? in other words if I were to lay a bare framerail on its side, would it lay flat. also what other year frames have similar deminsions? anyone have any pics of straight frames?
thanks, John
it's not a brick, it's cruise control.
| | | | | | dgiorgi Unregistered | | dgiorgi Unregistered | Hi John, I have a low cab 36. I think the frame is shared with the same year car (master series) or so it seems the information I have read indicates that. Get yourself a HOLLANDER interchance parts manual or simply buy a interchange parts book for the chevy at the "FILLIN STATION". you will be amased at all the parts that can be interchanged between the 28 and 1952 chevys. Saves alot of time and effort..dgiorgi | | |
