0 members (),
187
0
Mod | | | Forums66 Topics128,274 Posts1,058,425 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34451 12/10/2002 1:42 AM | Joined: Dec 2002 Posts: 6 Member | | Member Joined: Dec 2002 Posts: 6 | Got a 'great' deal on an intake/ehaust manifold to replace my old rusty pitted leaking like a...you get the point. This one is a beaut with just a bit of carbon build. The damper was stuck so I shot it with penetrating oil and left it overnight-nothin. Taped it with a small hammer-nope. Heated it lightly with propane-again nothing. Any ideas? jeff | | |
#34452 12/10/2002 3:42 AM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | My idea is that is probably why it was such a great deal! Those things are very prone to freezing up due to rust. Try Aero Kroil from Kano labs, worked for me. http://www.kanolabs.com/ | | |
#34453 12/11/2002 2:36 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Jeff I read an artical on an old tractor site about rusted parts and the best method of freeing up 2 parts that are rusted together. Soak it in water. I did this with my gas tank sending unit it took me 2-3 days but freed it up enough to were I could work it back and forth and get some PB Blaster in there to finish the job.
The other possibility is to look up in the tech tips (I think it is there) about the article on electronic rust removal. That might be an option for you.
Just remember it didn't rust together in one day so take your time and don't rush it, you WILL get it freed up.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#34454 12/11/2002 3:32 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Kroil or PB Blaster are both good penetrants. My best luck with freeing the stuck riser is using acetylene to heat the manifold until it's red. You need to be gentle with everything, it's easy to twist the shaft or shear the pin through the balance weight. If it's to tough you might have to drill out the rivets through the flap then drive the shaft out. A mixture of graphite and linseed oil is the lubricant of choice to keep it from seizing again.
Fred 52 3600 69 C-10
#34455 12/11/2002 10:27 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Just be careful heating the cast iron, if you cool it too quick it may crack, if you heat the ends of the shaft red hot, and let it cool a bit then use candle wax on the end, it will get sucked inside also loosening it up. | | |
#34456 12/14/2002 3:37 AM | Joined: Dec 2002 Posts: 6 Member | | Member Joined: Dec 2002 Posts: 6 | Thank you all for the input on unsticking the heat riser. Can one penetrating oil 'really' make 'the' difference? I've been using Zep but, of course, with no success. I've heated it with MAPP gas many times, but with no success. I don't have acetelene available. Besides, it seemed risky-for me. I've got another question though. I live very near the coast in Oceanside, Calif. (that's Southern Cal). Our year round adverage daytime temp is 72. Sometimes it will get into the upper 40's at night.The damper is stuck in the open position. If I left it alone, would it be a detriment to function and/or performance? | | |
#34457 12/14/2002 4:12 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If I'd have noticed where you lived I would have told you not to waste your time fixing it. You'll never know the difference if it works or not.
#34458 12/18/2002 11:57 PM | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 | I had my damper cut out by the guys at Warners Exhaust when they installed my new exhaust system.
