3 members (55shaker, 1955 1 Series, WICruiser), 144 guests, and 1 robot.
Topics128,263
Posts1,058,348
Members48,485
#344426 12/04/2007 1:16 AM
When installing the rubber windlass around the door frame on my '54 4400, do I feed it into the channel and try to work it all the way around by feeding from the one end? Thank you.
1954 Chevrolet 4400 1.5-Ton Dump Truck
1946 Chevy 1.5-Ton Dump Truck
1944 Chevrolet 1.5 Ton Dump Truck
1955 4400 Dump Truck
1951 2 Ton Stake Body
Scott54 #344441 12/04/2007 2:18 AM
I believe that I started at one of the upper notches and went in both directions. I also used lots of lubricant. It gets quite tight where it passes between the dash and the channel.
1951 1 Ton Completed
