| | | Forums66 Topics128,034 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34371 03/31/2003 4:36 PM | Joined: Jan 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 33 | Hi, I am rebuilding the distributor for my 1954 3804 pickup and the vacuum advance unit on this one is on a 90° angle but looking in the manuals the unit used is on a 45° angle. Which unit do I use?. Thanks Dutch | | |
#34372 03/31/2003 8:14 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You should be able to use either one, but you will have to redo your vacuum line. Hose and nipples can be used, just don't usee more than two feet of hose, it will collapse.
Fred 52 3600 69 C-10
