1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34356 10/22/2003 11:53 PM | Joined: Oct 2002 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 60 | what companys cary 8 hole chevy rims 15" or 16" I got some good advice from my last post but I forgot to ask who sells the rims. no luck at junk yards there all the deep type rims , need the 3 & 3/4" set back. thanks Bill
Bill 1951 3/4 ton 5 window pick up 1955 GMC 1/2 ton longbed automatic
#34357 10/23/2003 12:34 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Check with www.stocktonwheel.com and do a search on google to see what you come up with. Have you looked at the swap-meet here on the`Bolt?
#34358 10/23/2003 11:29 PM | Joined: Oct 2002 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 60 | Luke your right stockton builds 16x6"tubeless wheels with the correct offset for 1951 truck. $90.00. each Powdercoated = $125.00 each. [email protected] thanks for the information. Bill
