3 members (Dennys28, 87GN, 1 invisible), 113 guests, and 2 robots.
Topics128,059
Posts1,055,818
#34356 10/22/2003 11:53 PM
what companys cary 8 hole chevy rims 15" or 16"
I got some good advice from my last post but I forgot to ask who sells the rims.
no luck at junk yards there all the deep type rims , need the 3 & 3/4" set back.
thanks Bill
Bill 1951 3/4 ton 5 window pick up
1955 GMC 1/2 ton longbed automatic
#34357 10/23/2003 12:34 AM
Check with www.stocktonwheel.com and do a search on google to see what you come up with.
Have you looked at the swap-meet here on the`Bolt?
#34358 10/23/2003 11:29 PM
Luke your right stockton builds 16x6"tubeless wheels with the correct offset for 1951 truck.
$90.00. each Powdercoated = $125.00 each. [email protected]
thanks for the information. Bill smile
