| | | Forums66 Topics128,026 Posts1,055,399 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34354 05/07/2002 1:37 PM | Joined: Aug 2001 Posts: 23 New Guy | | New Guy Joined: Aug 2001 Posts: 23 | I have a few flywheels and stuff, that I was thinking to fix up on my 49 3/4 ton. The plan is to use a 11" clutch and the ring gear for a starter with a floor button. the starter is changed to 12 volts and the ring gear will be 139 tooth all will go on a 261 that I will go thru. Anyone done this and what will be my problem if any?
sader dog
#34355 05/07/2002 8:21 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | My truck had an 11" clutch when I bought it. Still running the 6 volt starter on a 12 volt system, no problems with that. The problem comes with clearance when installing the fork in the bell housing. You will probably need a shorter ball stud. Mine was assembled the way I learned in high school where you loosen the bell housing bolts as far as possible, slip in the fork, then tighten the bolts with an open end wrench 1/12 of a turn at a time. Ugh!
Fred 52 3600 69 C-10
