| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34346 01/16/2004 7:55 PM | Joined: Mar 2003 Posts: 49 Member | | Member Joined: Mar 2003 Posts: 49 | Hello Wise ones, Last night I picked up a used 454 for my 59 panel! I have the motor and tranny mount figured out but now its time to find some headers. I have seen some block hugger headers in the summit and jegs catalogs I have also seen tight tuck headers advertised. Is there a difference between the two? Does anyone know what will work with the stock manual steeering set up. I want to convert to power steering eventually but will use the stock setup for now if I can.Please advise | | |
#34347 01/20/2004 5:29 PM | Joined: Dec 2003 Posts: 29 Member | | Member Joined: Dec 2003 Posts: 29 | don't quote me on this, but i have heard of people using headers from a 1st gen camaro for a small block, so maybe some headers for a 1st gen camaro with a big block may fit. just an idea, good luck, and let me know as i am shopping for a new powerplant for my '59.
'59 Chevy 1-ton '03 **** Lightning '96 Kawasaki 1100 zxi
#34348 01/20/2004 5:35 PM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Just got some headers for the 59 with a CSB in it. Went with the Block Huggers (Headman) - they only stick out 3 - 3.5" from the block.
I don't know what the CBB headers would be like - but you can call Summit and they should be able to tell you the details.
- Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
