1 members (baldeagle),
80
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 33 | I have a 1954 Chevy 4500 Short bus with Wayne body that needs a few pieces of new glass, and new window rubber. The side windows are no real concern. It's the front and rear windows. I doubt that it is possible to get original rubber, but what does done do to replace these items?
I have one rear corner window (orig. curved glass) that someone has replace with lexan or plexy, that I would like to have replaced in glass. Plus new window rubber and windshield rubber.
Has anyone with a bus tried to find these pieces? Anyone have a suggestion?
Thanks a lot George oldbus.us | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | George,
If you are able to post pictures, they might help us to help you.
Tim | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Most Glass shops have a glass run/weatherstrip catalog, bring in your old rubber and they can match it up....allthough you might have to buy 25-50'.... | | | | | Joined: Sep 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 33 | Thanks, I'll get a few pictures together. | | | | | Joined: Sep 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 33 | Good idea, thanks  | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Wayne builds the box, GM the chasis, cab and front sheetmetal. Therefore your rear window and any side windows will need to be replaced at a local glass shop.
~Jim
| | | | | Joined: Sep 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 33 | Thanks a lot for the info  | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Soffseal can match up just about any style rubber window trim you may have. Look them up in the web, and they have pictures to reference what you're looking for. Good luck. Tramp | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | You can also try Uni-Grip . They are OEM seal manufacturer for many buses. RV's, etc.
