1 members (baldeagle),
68
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I think I found a C 60. My question is, the cab does have two small spots of rust. Looking at the cab I can't believe its the same as the smaller truck cabs...is it? Not sure of the year but think it's in the 1973-1977 era. :/ | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 55 1st suburban, the cabs are the same size as far as I know, hope that helps. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | It is definately the same cab as the P/U trucks but uses a different front end, i.e., hood, fenders & grill. The dash is the same too. | | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | is that the same for 66-72 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I had a 78 GMC 6500. The cab was the same as a PU all but the firewall to fit around the engine.
Is there any of that going on with the older trucks?
Grigg | | |
