8 members (55shaker, Wheelie, Gdads51, baldeagle, Otto Skorzeny, ShopRag, 78buckshot, 1 invisible),
108
Mod | | | Forums66 Topics128,268 Posts1,058,384 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34265 03/21/2003 8:10 PM | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | I came across an NOS Offenhauser alum valve cover for my 216 (53 1/2 ton). I noticed the new valve cover doesn't have a vent slot in it like the original does. I assume that some air needs to be drawn into the valve cover somehow. 1. How critical is the venting, and if my current oil filler cap, (the flat kind with locking tangs) shouldn't be used, does anybody know a source for another suitable cap? I guess the chrome push-on caps are a possibility. 2. When replacing the valve cover gasket, is Permatex or some other sealer recommended? If so, does it go on the valve cover edge, the edge of the block surface, both?
Thanks | | |
#34266 03/21/2003 9:41 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Just get the oil filler cap with steel wool in it , you'll be fine .
Use no sealant ! the stock gasket will seal fine .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
