1 members (1 invisible), 100 guests, and 2 robots.
Topics128,265
Posts1,058,366
Members48,485
#34265 03/21/2003 8:10 PM
I came across an NOS Offenhauser alum valve cover for my 216 (53 1/2 ton). I noticed the new valve cover doesn't have a vent slot in it like the original does. I assume that some air needs to be drawn into the valve cover somehow.
1. How critical is the venting, and if my current oil filler cap, (the flat kind with locking tangs) shouldn't be used, does anybody know a source for another suitable cap? I guess the chrome push-on caps are a possibility.
2. When replacing the valve cover gasket, is Permatex or some other sealer recommended? If so, does it go on the valve cover edge, the edge of the block surface, both?
#34266 03/21/2003 9:41 PM
V
V Offline
Just get the oil filler cap with steel wool in it , you'll be fine .
Use no sealant ! the stock gasket will seal fine .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
