4 members (MNSmith, Charles in CA, Otto Skorzeny, Hotrod Lincoln), 59 guests, and 2 robots.
Topics128,052
Posts1,055,718
#342435 11/28/2007 2:04 PM
I did not get a responce in the Interiors Forum...so I will ask here.
I need a source for the rubber grommets that hold the defroster on/off rod in a recirculating heater. I can't find them offered in any of my catalogs and did not find in a search of the forums...Anyone give me a hand??
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
Blue 50 #342453 11/28/2007 2:52 PM
Beleive it or not you may find a suitable grommet at your local hardware store.In my area,ACE Hardware and Sears Hardware stores have good selections.
Drew
DrewP #342602 11/28/2007 11:13 PM
Try an electrical supply store. PICO is one brand name that comes to mind.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sedgewick #343186 11/30/2007 12:44 PM
looks like I will give "the helpful hardware place" a shot...thanks
Blue 50
1950 3100 w/57 235
Blue 50 #343188 11/30/2007 12:53 PM
If the hardware place does not have it, you might check out Restoration Specialties. It takes some time to search through their catalog.
If you have the old grommet, you can mail it to RS and they will try to match it up (they will send it back, too).
Tim
What DrewP said... I've found that my local hardware store sells quite a bit of stuff that can be used on our old trucks!!
And the best part is, you can tell the MRS that what you bought was to "fix the house"...hehehe
Another quality post.
Real Trucks Rattle
The right size is available at McMaster Carr. #9307K64 1/4”x 3/4”x 1/16” Buna-N Rubber, mil spec 35489
I have them, PM me Drew.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks, Denny, but I'm not the person that needs them. It's Blue 50 in the first post. smile
Drew
DrewP #343714 12/01/2007 10:56 PM
Hey Denny,
I sent you a PM.
Chuck
Blue 50
1950 3100 w/57 235
Blue 50 #344193 12/03/2007 5:36 AM
I knew I'd seen that grommet listed by a vendor. If you still need the grommet (and/or are taking advantage of Jim Carter's end-of-year discount - promotion code JC112), Jim Carter sells the grommet (FL143).
Tim
Tim,
Thanks for the heads up, but the link shows a parking brake handle grommet...is that the same size as the defroster rod grommet I am needing??
Just looked at my PM's and Santa is arriving early....Thank You Denny for your generocity!!
Chuck
Blue 50
1950 3100 w/57 235
Blue 50 #344308 12/03/2007 6:25 PM
Chuck,
Sorry & Thanks for the correction. I think you are right and I am wrong. I'll confirm that this evening and edit my incorrect posting.
Tim
