7 members (3B, Phak1, 1955 1 Series, Gib70, Joe H, KEVINSKI, 1 invisible), 133 guests, and 2 robots.
Topics128,092
Posts1,056,451
Members48,443
#34212 02/20/2004 3:06 AM
Junior Member
Junior Member
I have a question that I'm hoping a fellow stovebolt owner could solve. I'm new to this forum so please bare with my pesky questions. I have a 1949 chevy 6400 it has a 2 speed rear end and it has an oil fill plug on the backside of the pumpkin (where it is normally) but after cleaning the rearend up I discovered what looks like a oilfill plug up front by the yoke. could anyone please help inform me about this set up. thanks
#34213 02/20/2004 3:10 AM
49, think that is an adjustment of some sort.
I cant think of the name right now.
1951 1.5 ton 4400
#34214 02/20/2004 3:16 AM
That is possibly the adjustment for the ring gear thrust block. It keeps the ring gear from deflecting too much under severe load.
Jason
#34215 02/20/2004 3:56 AM
Junior Member
Junior Member
so to correctly fill the differetial lube it should be level with the plug on the back of the pumkin?
#34216 02/20/2004 3:57 AM
Junior Member
Junior Member
by the way thanks for the info it is much appreciated
#34217 02/20/2004 4:19 AM
Junior Member
Junior Member
Thank's Ralphy I'm glad you have that shop manual I need to get one for my truck.
