0 members (),
83
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | The 478CID V-6 GMC < if one wanted to put one of these in a regular pick up sized dually truck.
1. could it be bolt up to the SM-420 trans ?
2. if not is there a M/T trans about that size one could get ?
I'm not trying to stuff a 2 million ton 9spd from a KW in pickup truck. . . NV-4500 or T-56 or somthing ?
Mike
1962 GMC K3000, GMC-379 V6.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | NV4500 is probably a good choice.
Did the 478 only have an SAE housing (round) like the V12, or did it have a more traditional automotive housing (not round)?
The SAE housing gives more options for transmissions larger than the SM420. | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | I think so I haven't seen oneup close and personal I was just looking at it on the 6066GMC site. . .
I don't want to put a HUGE tran's in that truck. . . I would like a 4-6spd manual trans, if they can put a 5.9L 24 valve in a monte they gotta have small enough manual trans to put a 478M in my GMC !
I saw on the site where a guy put the 478 with an alliosn auto in pickup truck a 3/4ton I think I would be interested in doing that but not with an auto trans. . . Any idea on the gear ratios of the NV-4500 ? I would like to gain an OD while still retaining my Granny. . . any idea on a 6spd tran's for this ? granny first and OD 6th gear ?
Mike
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | i have looked up every photo I can grigg and best I can tell it's perfect round mounting plate so dose this mean that about Any Heavy duty trans would fit it ? so i wanted the 5spd spicer ? or an 18spd fuller ? either trans would bolt right up ?
the 379M-V6's i have seen went both way's is it possable the the backing plate comes off ?
wouldn't the Mack or spicer 5spd or 7spd be way too heavy for the light duty chassie ?
Mike D
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I asked my friend who runs a few of them still. He said that yes the 478 only has the SAE #2 (round) housing.
So yes most any heavy duty transmission would fit.
The smallest Roadranger is the model RT(O)-610 or 6610 at 357 lb without oil or clutch housing, about 400 lb installed.
Eaton Fuller and Spicer all make some nice single countershaft 5,6, and 7 speeds that may not be to big. I don't know much about them, other than they are generally synchronized.
Grigg | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | I see. . .
so i'll have to get the old tape measure out see what i got for room and what i got for option's. . .
Mike
